bike doesn't start
Old Oct 26, 2010 | 10:17 AM
o2compressor's Avatar
Default bike doesn't start
At first the headlight stopped working not because of the bulb or fuse since they looked fine. The next day the bike would not start at all. No noise no nothing. The fan still turns on, horn works, blinkers and taillights all work. Any idea what the problem may be?
Old Oct 26, 2010 | 10:27 AM
bigboi18184's Avatar
It may be the starter switch, take the two Phillips head screws out of the bottom and check the soldering on the push button start switch. The headlights are wired through here to turn them off when starting the bike. If the solder has come UN-done it can make the headlight not come on and nothing happen when you push the start button.
Also make sure you have the on-off push-button in the down position.....just a reminder
umniks
Oct 23, 2012 06:47 PM
h0ndafanat1c
Aug 23, 2012 10:43 PM
cbrf3monkey
Jul 17, 2010 02:19 PM
dwarfdwarf
Jul 4, 2009 11:31 AM
blackhawk411
Jan 29, 2009 08:40 PM
