-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Big problem with the HISS (https://cbrforum.com/forum/general-tech-9/big-problem-hiss-87374/)
jonmorera Feb 11, 2009 01:24 PM
4 Attachment(s)
I recently had a crash with my bike, is a 2000 CBR F4 JDM, the crash was so hard that the tach broken the HISS system and now my bike not start.
my question is this, exist a possibility to solve this in an economical way?
Please I need help with this, I just finished buying all new parts for my bike and am ready to go again and only for this problem I'm stranded.
please help help :o:(
I am from Costa Rica sorry if my english is bad, this is my bike later and after the crash:
Attachment 65020
Attachment 65021
Attachment 65022
Attachment 65023
jonld Feb 11, 2009 04:55 PM
Have you plugged your headlight back up? the bike wont start without the headlight unless you bypass it.
jonmorera Feb 11, 2009 05:38 PM
Yes the headlight is plugged..
since the crash the bike not start, the light of the HISS is on all time, the module of the HISS in the ingnition switch is broken and is possible that this not read de code in the key.
jonld Feb 11, 2009 06:27 PM
Is this HISS your referring to something aftermarket? The only thing in the ignition switch on our bikes is a zener diode. If that is what is messed up then you can replace the ignitions switch or do a search on this forum or cbrworld for the zener diode. I posted the part number a couple years back but havent repaired any in awhile so I dont remember off the top of my head.
jonmorera Feb 11, 2009 10:41 PM
Not is aftermarket, it's OEM part, it's on top of the ignition switch (have the labels HISS) where is the key to start the ignition.. I will take a photo to better appreciate.
justasquid Feb 12, 2009 10:57 AM
thats not good news. As far as I know, there is no way to bypass the HISS. that was the whole idea behind it. A theif couldnt take your bike and make it work no matter what. It looks like you'll be in for a new iginition and new HISS system. The HISS system is a matched key with the ignition. There is an internal chip inside of your key that sends a message to the bike that it is ok to start. without one or the other, the bike will not start. Depending on how bad it is damaged, you may beable to buy a used system and then take it to a dealer and they should be able to re-program it to your bike.
But, I have heard that you can buy an ECU designated for the US market and replace your current ECU with the american version and it will then work. The US versions do not use the HISS. just what I've heard, so no gurantee's on that one.
jonmorera Feb 13, 2009 08:55 AM
Yes you have all the reason, I need a new ECU US version to eliminate the HISS system, the good new is that I already have the new HISS module, I bought this in the ebay.co.uk, thanks to all..
