Best way to test fan
I am starting to wonder if my fan is kicking in or not. It's worked before and I've heard it go on before but just not recently.
Had issues of engine nearly overheating twice now. Not even that hot outside. Never had such bad high heat problems...
Best way to go about testing if fan is working?
Most of the fans on our bikes (I'm assuming your talking about the radiatory cooling fan) are controlled by a Thermo-Switch. The fan has 12v going to it and the ground side is attached to that Thermo-Switch. When the switch gets hot enough, it closes the circuit and the fan turns on. You can bypass that Thermo-Switch and just short the leed that goes to it to the frame and see if the fan comes on.
