Before buying a new bike...
Old Dec 29, 2004 | 06:12 AM
300C's Avatar
Default Before buying a new bike...
When buying a bike, what sort of things should you look for to see if it's in good shape? As well, if water gets in the gas tank should you do anything? Thanks.
Old Dec 29, 2004 | 08:34 AM
slodsm's Avatar
Default RE: Before buying a new bike...
If you are talking used from a private seller, I would look at the chain for proper lube and tension, the lower shock mount for rust, the tires for wear and proper inflation, and the coolant level. If all of those are in good working order, chances are he took care of the bike and didn't just put gas in it and beat on it. Another thing to look for is under the tail for chunks of rubber to see if he may be a burnout king, that would indicate a hard life on the bikes part as well.
Old Dec 29, 2004 | 12:13 PM
NeonspeedRT's Avatar
Here is a page that has lots of good info for you. Things to look at, things to do, and things not to do. Good luck with your purchase: http://www.clarity.net/~adam/buying-bike.html
Safda
Feb 22, 2010 09:40 PM
Jng1204
Jul 20, 2009 02:52 PM
newbe
Aug 5, 2008 07:57 AM
Barkstrom_JB
Jun 5, 2008 04:40 PM
kcundle
Dec 21, 2007 08:33 PM
