Battery tender
Old Dec 11, 2013 | 05:36 PM
MegaZ's Avatar
New Member
Default Battery tender
New to the forum, but I once owned 2 CBR 600's. My brother owns a 2006 CBR 600 and his battery died recently. I suggested he buy a battery tender. Our question is can a battery tender pigtail be permanently attached with easy access to the pigtail?
Thanks...
Old Dec 11, 2013 | 06:56 PM
CorruptFile's Avatar
June 2013 ROTM
Yes, absolutely. That's a very common 'mod' for people. You can get a 2-pole connector (like this) and wire it to the battery (make sure you put a fuse on the +'ve side!!!!) The other connector can be wired to your tender. Easy-peasy.
Old Dec 11, 2013 | 07:18 PM
MegaZ's Avatar
New Member
The tender I use on my VRod has regular battery clips and the pigtail ends with a dipole connector, but I don't use it that way because the battery is easy to get to. Brother thinks his battery is too deep in the guts. Think a pigtail like mine will stay attached at the battery thru the SpringSummerFall?
Old Dec 12, 2013 | 06:40 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I wouldn't recommend regular battery clips as a permanent attachment if someone plans on riding with them attached. You can purchase a pigtail with ring terminals for the Battery Tender separately on Amazon and other places.
Also, tell your brother that he can get a Battery Tender Jr, complete with the above pigtail, for less than $20 with a bit of searching around.
Old Dec 12, 2013 | 09:26 AM
MegaZ's Avatar
New Member
Thanky
estate4life
Dec 4, 2012 11:08 PM
wickedambush
Jun 13, 2007 11:22 AM
PITBULL08
May 17, 2007 12:24 AM
esteei65
Dec 10, 2006 06:05 PM
mindz
Jan 15, 2005 04:41 PM
