arrrggggg Bike wont start when the engine is hot
can any body help, I have a 2002 cbr 600 F2, (in yellow)
The bike runs great, except, when the engine gets hot, then it WILL NOT start off the starter button. it will start if its bumped (pushed).
if I leave it to cool, it will start off the the starter button again.
I have changed the plugs, air filter, oil/oil filter. checked the compression, and checked all conections.
please, has any one got any ideas.
I had similar problems with my CBR600F2. I cleaned the carbs, and problems GONE! :-) You have to be VERY careful. Make sure you get ALL of the little passages. Dismantle carbs, spray carb cleaner, soak for 1 hour, use HIGH PREESURE air to blow out all the nooks & crannies. Blow out all the jets. Replace any worn out parts. Check float levels, assemble, sync carbs. The engine will run MUCH better!
jbalber
F2 Tech
10-02-2012 05:52 PM
byc_panty
07-09-2007 03:21 AM
