Anyone run octane boost? Will it hurt the bike?
Old 11-03-2008, 10:49 PM
1000ccrider's Avatar
Default Anyone run octane boost? Will it hurt the bike?
Anyone ever run Octane boost in your 1000RR?
Is it a good or bad thing to do once in a while?
I know in cars it works good to clean and lube injectors as well as the added octane helps.
Old 11-04-2008, 12:03 AM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: Anyone run octane boost? Will it hurt the bike?
Waste of money, it wont do anything for performance. If you want to do something for cleaning, your better off adding a cap ful of seafoam every now and then.
Old 11-04-2008, 03:03 AM
justasquid's Avatar
TK is 100 percent correct.
The only time more octane will boost your performance is if your running octane that is too low for your engine. In fact, runningfuel with too much octane will actually hurt performance.
Higher octane means its more resistant to pre-ignition. So, by adding octane booster, your actually making it harder for your fuel to ignite.
Old 11-04-2008, 09:00 AM
Thanks for the info, it makes sense. Is the seafoam safe?
Old 11-04-2008, 10:07 AM
TK954RR's Avatar
Jan 2009 ROTM
Yes, just make sure you follow directions and do not add too much.
maniacmechanic4
10-28-2009 09:00 PM
__Z__
08-07-2009 06:37 PM
Barkstrom_JB
05-28-2008 01:38 AM
MattBoyIU
09-10-2006 11:45 PM
fiveoh
09-09-2006 09:49 PM
Quick Reply: Anyone run octane boost? Will it hurt the bike?
