After winter check
Old Jan 24, 2009 | 10:43 PM
jDeArMeAmNy4's Avatar
Default After winter check
What are some things that you guys would check/replace after winter to make sure they are in good working condition. This is my first bike and the first winter ive ever gone through with it.I think my chain and sprockets need replaced because it is loose and last time i tightened it, it went into the replace chain part if the indicator.I know change oil. What are some other things you guys would check / replace.. thanx
Old Jan 25, 2009 | 12:06 AM
justasquid's Avatar
Default RE: After winter check
Im not sure if you did, but a before winter check is more important as your bike will be sitting for some time. Hopefully you used a good fuel stabilizer, lubed the chain, filled the gas tank, used a battery tender....ect.
As for your checkup on after winter. Your on the right track. Check the condition of your chain and sprockets, check air pressure in your tires, (should bedone at least once a week during yourriding season).Nows also a good time to go over tires really close to inspect for any checking, cupping or dry rot. Oil change as you said. Check to make sure all of your blinkers, lights work. Check to make sure throttle returns freely. check brake feel to make sure front and rear still feel good.
Potentially a brake fluid flush and change... depending on your mileage. Also, a coolant flush and refill .. again, depending on miles and or years on the current coolant.
I would pull it out and give a really washing. Dust and grime will collect over the winter and should be removed before you start to ride.
Old Jan 25, 2009 | 02:13 AM
lets see... i have an 02 f4i with about 20,000 miles on it.. i bought it from a motorcycle tech that works at shanendoah honda in VA. He said that hedid the 16,000 mile maintenance but im not sure what all that is. before winter i filled up the gas tank, used sta-bil fuel stabilizer, lubed the chain, and did a real good wash before i put it away.. i did not put it on a tender, ive just been starting it every week and so far so good its been starting right up.
i took it for a ride friday and i filled the tires up, filled the tank back up, and all the lights/blinkers worked. also i did not notice anything abnormal from the throttle or brakes, but i will be changing the rear pads because they are getting a little low. i did put a piece of cardboard under the bike and nothing is leaking.
my grandmother just got a big shed about the size of a 1 car garage and its being stored in that (in the cold).
im just worried that i will forget to do something that will either mess the bike up or mess me up if there is some kind of malfunction. thanx for your help guys. hope im not being annoying
Old Jan 25, 2009 | 01:39 PM
justasquid's Avatar
yeah, classic is right. It sounds like you did everything fine. the 16,000 mile check should have included a valve check, so you shouldnt have to have that done until after 32,000 miles, and thats good because to have a dealer do it, its a bit pricey.
The only thing I would suggest not doing is starting the bike up once a week. It sounds like a good idea, but when the bike is sitting in the cold, starting it up for a few minutes only creates condensation everywhere, which can lead to rustand corrosion. Its not a bad ideaevery 6 weeks or so togo and start it, butlet it run for a long time. making sure everything is equally warmed up. This will also recoat your engine's internals with oil. but again, the bike needs to run for quite some time to make sure no condensation forms.
Old Jan 25, 2009 | 07:50 PM
Hcstreetriding's Avatar
since i had electrical problems before with my 954 i like to check all the wires and electrical components too, make sure everything is plugged in and secured well and there are not any visible areas where the wires are getting worn or melted and no corrosion on the plug heads. also, just because i had problems with mine, i like to check the charging system and make sure its working properly every few weeks or so and will do so when i get it back out after the winter. most importantly, after winter and get back out to ride, be safe, everyone wants to get out and ride hard after a long frustrating winter, just dont push it too hard and get yourself in trouble or hurt. I cant wait for winter to be over!!
Old Jan 26, 2009 | 06:01 PM
oh yeah classic i did forget to mention i changed the oil at 18,000 and right before winter.. never thought about the electrical connections so ill deff look into that. i usually start the bike for about 10 minutes so ill make sure it runs for a while from now on.. thanxs for all your help guys
G_954rr
Dec 17, 2011 10:57 PM
jDeArMeAmNy4
Jan 24, 2009 10:49 PM
Syphen
Dec 15, 2007 12:21 PM
cbrrookie
Apr 23, 2007 09:16 PM
gamble
Nov 27, 2005 09:00 PM
