Advise
you'll need new brake lines.... you can call galfer say "hi, i want SS lines for my f4 + 5 inches because i'm running different bars"
throttle cables usually work, as does clutch cable....
if they don't you need to measure how long they are then add however many inches you think you need- find a company that makes throttle cables and order new ones for the length you need.
simple. if your wiring doesn't stretch (which it should), cut and splice - then solder and shrink wrap some wires into the harness to make it fit
simple
simple
