99 900rr gauges, need help
Old May 20, 2011 | 01:00 PM
jsem's Avatar
Question 99 900rr gauges, need help
Hello all, could use a hand here. Got a 99 900rr and i'm having issues with the gauges. Tach, speedo, odometer and temp are all dead. I do have power because the background lights are all on. Signals work and neutral light, high beam all work fine. Just no reading on the gauges. Everything was working fine, parked it for a few weeks and wouldn't start due to weak battery. At that time i needed to install a new flasher for the signals since the old one wasn't working. Did that signals were working again and I still had working gauges. Put it on a charge and it started right up, but gauges were non responsive. Pulled the new flasher out and put the old one back in, still nothing. I checked all fuses and there fine. I disconnected everything from the wiring harness and removed all the black tape to see if i had a short. Didn't find anything out of place, loose or pinched. I even took the gauge cluster apart to see if there were any signs of overheating, nothing, all normal. Checked the grounds and they were tight. This is frustrating, the bike runs fine i took it for a quick ride and all were good just no reading on the gauges. Could the gauges cluster be shot?? I hate to buy another one and get the same results. Any and all help would be greatly appreciated.
Old May 20, 2011 | 09:07 PM
MadHattr059's Avatar
Try hosing all the connectors with contact cleaner. Then re-connect everything and see if that fixes it. Check a manual and test the send-units to the guages, to assure they work. Then get a wiring diagram and start testing the harness connectors for continuity or short that you can't see. If you eliminate the harness and the sensor's themselves, it pretty much says bad guages.
With the expense replacing them will cost, you might still consider taking it to a pro for an expert opinion before dropping the change on a new set of guages.
Ern
Old May 21, 2011 | 05:43 PM
jsem's Avatar
Ok I'll give that a try. Thanks
Old May 21, 2011 | 08:41 PM
No problem, I feel your pain. I'm chasing a gremlin on my beastie that pegs the RPM guage. Not the engine just the guage. sigh. Just when I say, "Done!", it's always something. Good news is, I'm not a thrasher, so I don't really need the darn thing, my ear is good enough, just hate the 95% feeling. ;-)
Ern
Old May 22, 2011 | 08:29 AM
jsem's Avatar
Its always something with these machines. I dont know about that one, maybe check the sensor or the wire. Getting a false reading somewhere. I got my gauges working. Turn out to be a ground wire that was broken. At first glance it was all connected, turned out that the wire strands inside the green was broken. Only way I found it was to run a jumper wire from the connection in back of the gauges to a ground. Soon as it touched they came on. Traced that wire all the way back to where it grounds to the frame. Sneaky little bast*rd.
RR MIKE
Jul 14, 2022 12:52 PM
JHOOK900RR
Nov 17, 2008 09:28 AM
900RR Brad
Aug 3, 2005 05:40 PM
