Is the 520 chain conversion worth it??
Old May 30, 2007 | 07:04 AM
Roach's Avatar
Default Is the 520 chain conversion worth it??
I am wanting to up the gearing on my 06 CBR1000RR and am trying to decide if it is worth it to me to spend the extra money to to the 520 conversion. Is the 520 conversion really worth it to the average street rider?? Its either $70-80 bones for a good rear sprocket or $220+ for a good 520 set.
Just trying to improve starts and launches, and maybe gain a little acceleration. Stock is 42 so maybe an AFAM 44? Will the stock chain be ok with +2 on the rear??? I could go down -1 on the front for less money but I worry about what I have read about the fronts not being dampened. Is this really an issue? Plus, if I do the back, I can get ride of the ugly stock steel.
If someone convinces me that the 520 is worth it, what brand and model chain? Good source to buy? Remember, I am street riding. Maybe in the future some track days, but nothing too serious.
Thanks
Roach
Old May 30, 2007 | 01:27 PM
Tahoe SC's Avatar
Default RE: Is the 520 chain conversion worth it??
i say stick with stock chain size and just do the sprockets.
the 520 part isn't what you feel the most (just what you feel most in your pocket)...it'll be the re-gear. try it out...bet you won't be able to tell much.
Old May 30, 2007 | 03:38 PM
knightslugger's Avatar
i agree. stick with the 530 and just regear it. If you buy a 520 kit and keep the gearing the same as it is now, you won't know the difference and you'll kick yourself in the nuts for blowing so much money on it. just regear.
Old May 30, 2007 | 04:07 PM
bushmasterAR15's Avatar
You mean the 520 doesnt add 5 hp and 10 mph to top end?!?? I am sending mine back!!
Old May 30, 2007 | 04:45 PM
Tahoe SC's Avatar
only if you put on the sticker that says DID or RK.
Old May 30, 2007 | 05:30 PM
Wouldnt that add weight and make me lose top end?
Old May 30, 2007 | 05:53 PM
Roach's Avatar
Thanks guys. Just confirms my thinking. I will skip the 520 this time around and the money I save with just the rear sprocket will get me some other goodies to add to the order.
So +2 up on the rear of the 06 is ok? Stock chain length ok?
Thanks Again
Roach
Old May 30, 2007 | 06:32 PM
bosshaus1's Avatar
the reason i did it was because the chain my bike had on it when i bought it was a p.o.s as were the gears, i found a +1,+2 520 RK/vortex kit for $150 on ebay...of course the chain is stronger but the acceleration kit sure is nice onthe little 900rr...for you it is probably a waste of cabbage..
Old May 31, 2007 | 09:21 PM
kustom98f3's Avatar
It isn't always a good idea to change sprockets w/o changing the chain to. A worn out chain will wear out new sprockets really quickly and vice versa. Wait till you have to replace the stuff then regear.
baddest
Aug 3, 2011 01:22 PM
SLOrider954
May 15, 2011 04:17 AM
elcoomagnifico
Mar 22, 2011 12:02 AM
fastspares
Mar 22, 2010 02:29 PM
mtxkidd2
Sep 30, 2007 12:18 AM
