is the 520 conversion worth it
Old Jan 7, 2008 | 05:50 PM
elcoomagnifico's Avatar
Default is the 520 conversion worth it
right now i have my bike apart and was maybe thinking of doing the 520. what do you guys think? is it worth it
Old Jan 7, 2008 | 06:09 PM
knightslugger's Avatar
Default RE: is the 520 conversion worth it
if your chain is within specification for stretch, then no. if it's ready to be replaced (which means new sprockets too) then yes, but depends on the specifics. a conversion is only a conversion of the chain pitch. 's got nothing to do with the diameter of the sprockets. that's just a simple gearing change. a 520 is lighter and is sometimes cheaper and stronger than a regular 525 pitch chain.
again, depends on the specifics. no simple answer.
Old Jan 7, 2008 | 06:44 PM
Blue Fox's Avatar
Retired Moderator
When it came time to replace my chain and sprockets, I did the 520 conversion with the stock gearing. I couldn't feel any difference in power, responsiveness, nothing really. You get less rotating mass, but it's so little that it really doesn't matter for street applications. When you're trying to improve your lap times by .05 of a second.......maybe. But for street, it really doesn't matter.
Old Jan 7, 2008 | 07:58 PM
baxsom's Avatar
for a street bike going to a 520 in stock gearing wont be a noticible difference. because you wont (read shouldnt) being doing 100mph curves
for a street bike any change in gearing in 520 or 525 will be more noticed than a slip on
for a track bike the 520 will be more noticed on high speed corners due to the less rotating mass.
Old Jan 7, 2008 | 09:05 PM
krash's Avatar
I agree, unless your serious racing, you'll only notice in your wallet. more expensive, plus it wears out quicker.
Old Mar 18, 2011 | 12:20 PM
zieper41's Avatar
Default 520 Conversion
Yea same thing as the guys above said. Unless your changing the sprockets along with the chain its not worth it. I just did a 520 conversion with 14/45 sprockets from 15/43 and theres a hell of a difference.
Old Mar 18, 2011 | 10:41 PM
Dissevered's Avatar
For the street, stick with the bigger chains. You can always do a gearing upgrade, but don't bother with 520. They wear out too fast.
Old Mar 19, 2011 | 07:43 AM
MadHattr059's Avatar
Ditto, all of the above. If you have to ask about this "upgrade", you don't need it. The race track is the only reason to make this conversion.
Old Mar 21, 2011 | 11:03 PM
philthethrillohio's Avatar
get it !
Old Mar 21, 2011 | 11:20 PM
oldskool21's Avatar
if u buy the rk chains kits they come with a 20000 mile guarantee,i just went frome 16/46 to 15/46 nd i could tell big time u get more power at the rear wheel
