2004 cbr1000rr won't start?
Old Jul 13, 2006 | 01:57 PM
hyperriderz's Avatar
Default 2004 cbr1000rr won't start?
I know it's fuel related because bike will run with gas poured directly into intake side. One thing i don't hear is the fuel pump prime when i turn the key on. I am trying to figure out if it's the fuel pump itself or if it's the fuel pump relay. I have no manual and i can't seem to locate the pump or relay, can someone help a brother out? I think it may be tucked away under the airbox somewhere but not sure. As far as the relay goes how do i check it once i in fact locate it. I always thought they were either good or bad. Help HElp Help!
Old Jul 13, 2006 | 02:39 PM
pitsvtec's Avatar
Default RE: 2004 cbr1000rr won't start?
Was anyone throttling the bike while it was off?
Old Jul 13, 2006 | 03:49 PM
MgA_ODEN's Avatar
ORIGINAL: pitsvtec
Doesnt matter FI.
ORIGINAL: hyperriderz
I have no manual
Right click and save this file is 327 MB
>>> Service Manual <<<
Old Jul 13, 2006 | 04:29 PM
What does throttling have to do with it? That does'nt hurt anything!
Old Jul 13, 2006 | 08:06 PM
isolated1523's Avatar
Retired Super Moderator
Had it apart lately? Puttin the bank angle sensor on upside down is a common mistake that will cause exactly what you have.
-Adam
Old Jul 14, 2006 | 03:25 PM
where is the bank angle sensor located? I also want to know where the fuel pump and relay are.
Old Jul 14, 2006 | 05:38 PM
MgA_ODEN's Avatar
Between the headlights , there is a pic in the manual.
Old Jul 14, 2006 | 08:33 PM
1000RR's Avatar
The fuel pump is IN the gas tank.
You should hear the pump for about 3 sec on power on.
With any of your 8 injectors unplugged, the fuel pump will not run.
Same goes for the MAS on top of the airbox. It's gotta be plugged in.
Did you recently have the tank raised? If no, hard to say, if Yes you did something
like pinched the fuel line (gotta route it on the tank bracket) tugged a wire etc.
Seriously, you NEED to download the service manual. It tells you how to troubleshoot
the fuel pump.
Old Jul 15, 2006 | 05:35 PM
I checked the lean angle sensor all plugged up same with the head lights and checked the plugs for the fuel rail. I have power to the fuel pump but when i had the ignition on i unplugged and plugged it back in, nothing! I'm pretty sure it's the fuel pump. Has anyone heard about a 2004 cbr 1000rr having fuel pump problems with only 7,500 miles on the bike?
Old Jul 15, 2006 | 07:59 PM
MgA_ODEN's Avatar
Nope.
tomc1965
Jul 18, 2007 06:41 PM
rogfog
Sep 12, 2005 04:04 PM
