2003 600rr EFI and OIL light
Old Apr 19, 2006 | 11:18 PM
wuzwuz's Avatar
Default 2003 600rr EFI and OIL light
hi i have a problem that three michanics at different honda deales didn't exactly know what it is
if someone knows please help!
between 10 to 15 thousand rpms the EFI light and OIL light comes on and the bike shuts off completely
this happens while riding or in neutral
it mostly happens in first and second when the rpms go up really fast
allways happens in neutral
michanics suggestions are:
faulty ecu (thinking there is a prblem with the injectors)
faulty oil pressure sensor (shutting the bike off thinking no oil is getting to it)
faulty kerb sensont (thinking the bike fel over and shuts of moter)
Old Apr 21, 2006 | 10:28 PM
wuzwuz's Avatar
Default RE: 2003 600rr EFI and OIL light
after 4 houres of searching for the problem i took almost the whole bike appart
i found that the cluster connector came a little loose and it wasing making continouis contact all i had to do is unplug the cluster harness and replug it back in
thank u all for comin out
kotkotusa
Jun 11, 2010 06:15 AM
duadod
May 26, 2007 06:52 PM
