2002 exhaust header pipe studs and nuts
Old Jul 27, 2011 | 09:14 AM
highwaypatrol's Avatar
Default 2002 exhaust header pipe studs and nuts
Hi. Does anyone know where I can buy some exhaust header pipe studs and nuts in stainless? All mine came out with the nuts still attached and I broke a stud but luckily it came out with a stud extractor. The nuts should have come off and left the studs in the head, but they were all corroded to the studs. Copper slip comes into mind! Just wish the previous owner(s) had used some! LOL! Thanks.
Old Jul 27, 2011 | 02:33 PM
Honda125 358's Avatar
I had the same problem. I'll be buying new oem ones. I've never seen them in stainless...I'm sure you could get a machine shop to make some but I'm sure that'll cost more than you care to know...
Old Jul 28, 2011 | 12:57 AM
dannoxyz's Avatar
Just replace the nuts with stainless and it won't stick to the studs so badly.
Old Jul 28, 2011 | 02:49 AM
itlnF4I's Avatar
www.cheapcycleparts.com
Old Jul 28, 2011 | 04:00 AM
DonnyBrago's Avatar
What I do is use brass nuts instead of steel. Brass shouldn't corrode in the first place but if the stud corrodes stopping the nut from coming off the soft brass will strip before the stud snaps.
If you intend on EVER removing your downpipes again I would highly recommend brass nuts and copious amounts of copper grease, it doesn't matter what metal your studs are made from if you use brass nuts.
Old Jul 28, 2011 | 05:34 AM
Thanks to all of you great guys who replied. I eventually decided to go the OEM route and new studs and nuts are coming into my local dealer on Saturday. I agree about the brass nuts and copper slip and just wish whoever had the pipes off last had used at least the copper slip. While I'm waiting for new studs etc I've got plenty of time to clean the rest of the bike including the fairing, engine and silencer! Should look a lot better once it's all back together.
cBrentb
Aug 7, 2013 03:02 AM
wiltse
Apr 20, 2010 04:38 PM
RYDINRED929
Jan 16, 2009 12:08 PM
ForcedInduction
Mar 10, 2008 06:31 PM
