2001 cbr 600 f4i
Old Aug 11, 2016 | 08:32 AM
Keon Slayton's Avatar
Default 2001 cbr 600 f4i
Have a problem fuel pump not priming and spark plugs not getting fire replaced fuel pump New wiring harness replaced cdi still nothing three shops still nothing started day before took it to shop turned it off never started back up
Old Aug 11, 2016 | 07:19 PM
Default Need some help anybody THANKS
Old Aug 11, 2016 | 10:42 PM
Jaybird180's Avatar
Check Battery, then ignition switch, then main fuses, then swap ECU if you have good wiring.
Old Aug 12, 2016 | 04:43 PM
I have done all the above still having same problem
Old Aug 12, 2016 | 04:47 PM
74demon's Avatar
Headlight working?
IIRC, the BAS circuit runs though the headlight.
Old Aug 14, 2016 | 09:06 AM
Originally Posted by 74demon
Headlight working?
New harness in front headlight has always worked the engine have shut off while riding and start back up bout ten minutes
Old Aug 14, 2016 | 10:54 AM
74demon's Avatar
You failed to mention this piece of information.
Have you bypassed the BAS and tried it?
A while back, mine was shutting off after 40 minutes of riding and then would need to sit before the pump would start working again. Bad BAS....
Old Aug 14, 2016 | 10:59 AM
Jaybird180's Avatar
Also check kill switch and side stand switch. I'm also thinking rectifier is overheating.
Ceezz
Apr 11, 2014 11:28 PM
swizzy
Dec 31, 2009 12:19 PM
swizzy
Oct 22, 2009 01:18 AM
