2 questions
RE: 2 questions
A speedohealer plugs inbetween your speed pickup sensor and your instrument cluster and alters the speed signal so that the correct speed is shown on your display. All you have to do is program the healer with the proper correction factor in percent.
NO, you should not really smell gas in your oil.
RE: 2 questions
lol hotwire when i first read it and u said speedometer omg I was like.....poor guy but then i saw what u meant lol that was good! and no you shouldnt smell gas there it could be something internal I'll read up on it for ya cause im really bored get back to ya when i find out =P
RE: 2 questions
If someone didn't pour gas in your crankcase, it could only come from a leaky float valve in the carbs. Unless you have FI, then you have a problem. With your bike on the sidestand, gas can leak past a leaky petcock into the carbs. Usually no problem unless one or more of the float valves are also leaking. Then gas overflows the float chamber into the intake manifold. There the gas goes into number one cylinder cause it's the lowest. There it can cause hydrolock or leak past the rings into the crankcase. If it was mine, I would change the oil, repair the petcock, clean the carbs, and change the float needle and seats.
