1996 CBR 900rr gearbox rattle/noise
Old Jun 11, 2011 | 06:49 AM
Dally CBR's Avatar
Default 1996 CBR 900rr gearbox rattle/noise
Hello all,
My CBR has a rattle from the gearbox at idle, I can hear it with the bike idleing and feel some vibration, when I pull the clutch lever in the noise and vibration go away.
Is this a clutch issue or gearbox issue?
It does not jump out of gear or get false neutrals.
Cheers
Old Jun 11, 2011 | 08:07 AM
It's not uncommon for there to be some audible noise with the clutch released and just idling. Does it go away when you rev the engine ? How long has it been doing this ?
Old Jun 11, 2011 | 10:19 AM
Monkeybutt2000's Avatar
You're clutch basket may be getting worn. The clutch fibers have tabs that slide in between the basket. Over time (usually on higher mileage units) the tabs will ratttle in between the fingers of the basket due to wear.
Old Jun 12, 2011 | 12:31 AM
justasquid's Avatar
Im with IDoDirt on this one. More than likely is just the normal clutch noise. Unless its really loud, I'd say its probably just the normal noise.
If its really loud, you may have one of the bearings going out. But again, these bikes will have some noise at idle with the clutch out. the 90's generation of sportbikes tended to be a bit worse for the noise as well. My old F3 off the showroom floor was quite bad. And any 900RR I"ve ever heard seems to be quite noticable. But all bikes will do it a little, just some are more noticable than others.
SleepingJake
Sep 19, 2012 07:49 AM
StuartCBR
Jan 26, 2012 10:52 AM
BlackBlade
Jun 1, 2009 08:11 AM
pegasus
Jul 11, 2007 05:27 AM
dean7698
Aug 19, 2006 06:22 PM
