07 plate blade not fireing
Old Jul 10, 2017 | 09:37 AM
Dean Greatrex's Avatar
Default 07 plate blade not fireing
Hi there I'm new here and I'm looking for a little help please. I have a 07 plate blade and it's not starting. When you turn the ignition on the pump primes but then it just turns over. Seems to be no spark. Has anyone got any ideas please?
Old Jul 11, 2017 | 01:04 AM
CaBaRet's Avatar
Have you got any fault codes up
Old Jul 11, 2017 | 03:05 AM
no fault codes atall
Old Jul 11, 2017 | 03:18 AM
CaBaRet's Avatar
Have you had the direct ignition coils out to check for no spark , or can it be fuel related, also check neutral ,sidestand and clutch switches :0
Old Jul 11, 2017 | 03:40 AM
the aa checked the coils and said they was a signal. I'll check the side stand and clutch switches
Old Jul 11, 2017 | 04:08 AM
CaBaRet's Avatar
Hi if the AA saw a signal at the coils then you must have a spark , more likely to be fuel related, have you had the tank off lately?
Old Jul 11, 2017 | 04:35 AM
haven't had the tank off but have been useing fuel from a local garage. Could poor fuel cause a issue?
Old Jul 11, 2017 | 04:42 AM
CaBaRet's Avatar
Could if its got dirt in it, but after saying that ,the bike is 10 year old , when was the last time (to your knowledge) the pump was looked at, could even be pinched fuel line , but unlikely if you've not had the tank off, most likely though blocked fuel pump, was it acting up in any way before it stopped
Old Jul 11, 2017 | 04:46 AM
it's been running fine. Not sure when the pump or filter was looked at last.
Old Jul 11, 2017 | 04:52 AM
CaBaRet's Avatar
Hi do you have a workshop manual for the 07, if not you can download an 04-06 and a 08-14 off the net they will be close enough to do any fault finding with the fuel pump, but remember if you take the tank off the fuel line is under pressure , but after saying that if nothing comes out it will show the pump is blocked
