06 600rr - Did a header install and have a question *Pic*
Sup guys, just wondering if this gap between the 4 header collars/flanges and the engine is anything to worry about. I put squares around them in the pic so theyre visible. All studs were torqued down to OE specs (9ft/lbs) and new gaskets were used too. Just wondering why there's still some gap there, as you can see. Bike makes no noise, I feel no air escaping so an exhaust leak is unlikely. Or maybe I do have a leak and dont know it? Is a leak very noticeable? I just dont want to over tighten and strip a bolt. What do you all think?
If you installed headers on your bike, is this normal to have that gap between the collar/flange and the engine casing?
OK, that's better. Like they say, a picture tells a thousand words. You installed new gaskets right ? Did they look like the ones below (the one on the right) ? If so, the seal is created by the round portion of the exhaust header pipe squeezing the gasket against the head. As the gasket gets squeezed, it crushes a little and seals the gap. The space between the header flange and the head where the bolt comes out is needed because of this crushing of the gasket. The torque that you apply is what does the sealing.
The long and short is you're fine. That's the way it's supposed to be.
You can see there is a gap on these as well too. This is a factory header on an F3.
hey thanks for the reply. I was just a little worried because when I had my OEM headers, the gap between the flange and the head was minimal. THen with these Arrow headers its more noticeable - I'll guess because the flange of the Arrow headers is more slim.
Yep those are the gaskets I used
Update...I called Hyperflo today to place an order for my 600RR but they're back ordered till June 20th...If you're willing to place your order now, and wait (Until June), the price will be prorated on a weekly basis from now until they're back in stock...for this week that makes the price $715 shipped....next week it'll probably be $730 and so forth...
