05 600RR is running HOTT
Just got the bike back from a local dealer that did an 8K Mile service. some of the things they did were oil change synched throttle bodies, added coolant, checked coolant system, adjusted clutch, etc. Before the bike ran between 70 and 90 degrees depending on traffic. I saw the temp at just over 180 before I pulled over and shut it down. Is this something that normally happens after a service? What could be causing the temp of the bike to be so high? The bike didnt feel any different than normal as far as heat from the engine. I dont know, at this point I am confused and frustrated.
Slopoke is definately speaking in Celsius terms because those are the temps my bike runs at and my thermometer is in celsius.
Hey slo, I'm having the same problem. Bike usually runs somewhere in the 80s, and highest I recall it getting was 110. Then I had some problems with it, took it apart and put it back together (ended up being a loose battery terminal). Now it runs really hot, even on cool nights. Thermometer starts to flash around 122 degrees and the malfunction indicator light came on at 126 the other day. Fan never kicked in. I have no clue what's going on. I'm gonna have to have my buddy take a look at it, but if you figure out something let me know.
