05 1000 rr wont start
Old Jun 11, 2013 | 01:09 PM
Mxmeac's Avatar
Default 05 1000 rr wont start
I have an 05 1000 that wont start. Came out to start the bike and it acted as though the battery was dead, everything primed, then i hit the start button and it just clicked. I have a new battery in the bike and it started fine 5-6 times. I took her out for a 15mile ride, shut it off and it would not start again, so i jump started it. Got home, charged the battery. Same thing happened. The battery is perfect. I had a stator put in 2 years ago. Any suggestions?
Old Jun 11, 2013 | 02:54 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Here's a guide to determine if the charging system is OK.
Fault Finding Flow Chart for Motorcycle Charging Systems
Old Jun 12, 2013 | 04:37 AM
Mxmeac's Avatar
Thank u, but the link will not work. Can you try again
Old Jun 12, 2013 | 06:47 AM
RoadiJeff's Avatar
Hmm...I thought I tested it but here it is again. This time I'm sure I tested it.
If that still doesn't work for some reason, just do a Google search using those words. It's the first one in the list.
Old Jun 12, 2013 | 08:56 AM
Mxmeac's Avatar
Thats perfect. Thank you very much
Old Jun 12, 2013 | 06:38 PM
Mxmeac's Avatar
Thank you, im pretty sure its the rectafier. Do you know where and how to locate the rectafier? Its a 2005 CBR 1000 RR
Old Jun 12, 2013 | 06:51 PM
Mxmeac's Avatar
Also, what rectafier is the best value?
Thank you for all your help..
Old Jun 12, 2013 | 07:35 PM
RoadiJeff's Avatar
I'm not sure where you can d/l a service manual for the 2005. Mine is a 2008 and I could post the link to the PDF version of it but the bike design changed significantly in those 3 years and I don't think the '08 manual would do you any good.
Old Jun 14, 2013 | 08:53 AM
Mxmeac's Avatar
2005 CBR 1000 RR. Fully charged battery
I tested the battery 13.1 volts
Turned it on 12.5 volts at idle
Rpm at 5000 11.2 volts
Should i replace the stator? Or the rectafier? Also, im kinda stuck at taking off the upper left side ferring. I took out all the bolts, but its still caught on something?
Old Jun 14, 2013 | 10:08 AM
RoadiJeff's Avatar
Did you read the PMs I sent you?
