03 F4
Old Oct 28, 2007 | 05:59 PM
madchiwawa's Avatar
Default 03 F4
Hello i just got an 03 f4that was layed down (just messed up fairings) from a tow yard. I bought a upper fairing from a guy and it ended up off an RR not an F4 got every thing to turn on except the front turning light (still missing) and she just turns over i hear no fuel pump buzz all fuses check good including the main 30. any help..../??? i dont know if BAS is the same or not i am missing the compleat f4 upper fairing so have nothing to compare.......
Old Oct 29, 2007 | 09:51 AM
Tahoe SC's Avatar
Default RE: 03 F4
yes, if the cluster isn't plugged in (bas connector is in the bundle) then you will get no prime.either plug the cluster back on or jump the bas and it'll come on.
Old Oct 29, 2007 | 05:25 PM
madchiwawa's Avatar
Default RE: 03 F4
Hay thanx bro!! ill give it a try. I was hoping the harness would be the same......................LATE.........
