wiring undertail section
Old Feb 27, 2005 | 12:54 PM
77hogan's Avatar
Default wiring undertail section
I just put a custom undertail section in and wired it up now my bike wont start. I cut the 3 wires to the tail light and wired them into the aftermarket lights. I also cut the turn signals wires and wired the into the after market turn signals. but I had custom turn signals before and never had a problem. can some help[:@][:-]
Old Feb 27, 2005 | 07:37 PM
L8X's Avatar
L8X
Default RE: wiring undertail section
uh oh...maybe you cut something you weren't supposed to? or maybe you forgot to connect something. good luck!
Old Feb 21, 2007 | 11:15 PM
thunder31634's Avatar
Not sure what year model you have but my 01-04 manual shows the brake lights/ turn signals and the fuel cut relay and the engine stop relay all go through the same plug.....while you were working on it maybe that plug worked loose a little.....it would be the first thing i would check
and the really "noob" stuff like the engine cutoff switch/ tranny in 'neutral'
let us know if you make any progress or still need some help
rikubot
Jan 1, 2019 06:09 PM
mattnadz
Jun 26, 2012 11:24 AM
Dj_Squatch
Jan 17, 2008 11:27 PM
