Will this kit work on my bike?
http://cgi.ebay.com/Slim-Ballast-Kit...item3ef7f7644b
also what K should i get 5 or 6 k? thanks Mike |
it looks like it would work to me.... what colors your bike?
5k looks more yellow 6k looks more blue ide match it depending on the color of your bike... |
Originally Posted by zmds18
(Post 894310)
ive never actually installed a pair myself.... but i found this write up... not any pictures which is disappointing but i think its pretty similar for all hid set ups
http://www.bandofriders.net/forums/s...ad.php?t=29907 thats the link there are a few more needless pics there.... i dont take credit for this write up.... just passing it on |
Alright, time for an update. I wanted to install a separate fusebox for stuff like power plugs, heated grips, possibly a Garmin hardwire. Since all the parts came in already, I've been fiddling for the last two days taking my time with the fuse box. Probably spent way more time that I should have, but it came out nice.
Bike, check. Tools, check. Fairings and plastics came off easy since I remembered everything from the the slider fiasco the other day. Lifting the tank a bit, I saw the stock wiring and decided to run my wires alongside. http://sheepable.com/media/f4i/fuseb..._fusebox05.jpg Now for the best part. It's the FZ-1 from http://fuzeblocks.com. A bit pricy at $80 but nice as hell. It's tiny, pretty sturdy (check their website for crash pics) and has two internal buses. One is on a direct feed from the battery and the other one is controlled via a switched relay. For each device (you can plug 6), simply choose whether you want it always on or only when the ignition is on. Then you put a fuse in the appropriate spot. http://sheepable.com/media/f4i/fuseb..._fusebox06.jpg Even though this thing is small, I had trouble finding a place for it. So I used a piece of play-doh with approximately the height of the fuse box and after some experimenting with the seat, I figured out that the only place under the seat that can fit the fuse box is already taken by the Power Commander. Bummer. So I decided to mount the fuse box upside down with some velcro under the seat. This way, it will sit just above the owner's manual and tool box, with enough clearance. http://sheepable.com/media/f4i/fuseb..._fusebox08.jpg http://sheepable.com/media/f4i/fuseb..._fusebox09.jpg http://sheepable.com/media/f4i/fuseb..._fusebox10.jpg Next, wiring -- flexible heat-resistant tubing, some 16-gauge heat/water/oil resistant boat wire, inline fuse, heat-shrink ring connectors and some posi-locks. By the way, http://www.posi-products.com ... it's the ****. This stuff makes me not want to touch another connector again. So I went with 3 sets of wires -- one for a set of cigarette lighters (5A should be plenty, or I can install a bigger fuse), one for hardwiring a Garmin and one for heated grips. And back on the bike: http://sheepable.com/media/f4i/fuseb..._fusebox15.jpg http://sheepable.com/media/f4i/fuseb..._fusebox16.jpg http://sheepable.com/media/f4i/fuseb..._fusebox17.jpg http://sheepable.com/media/f4i/fuseb..._fusebox18.jpg Done for the day, happy with the result! Bike's getting dusty, so a cleaning is in order http://www.bandofriders.net/forums/i...milies/wub.gif then it's either HIDs or cigarette lighters. http://sheepable.com/media/f4i/fuseb..._fusebox19.jpg http://sheepable.com/media/f4i/fuseb..._fusebox20.jpg Hope no one steals my fairings. Thanks all. I don't have a cover yet but may get one for the winter. Here's the next "mod" -- took a fuse puller tool, chopped one end off, trimmed it, drilled out the hole on one side and was able to fit it into the fuse box. Not my original idea but oh well http://www.bandofriders.net/forums/i.../thefinger.gif I also installed HIDs the other night, pics incoming soon. http://sheepable.com/media/f4i/fuseb..._fusebox21.jpg http://www.bandofriders.net/forums/i...cons/icon1.gif So here's a little HID write-up. I am happy with the result, went with a DDM dual HID kit at 4500K. Looks pretty good, similar to the stock HIDs on my car. The ballasts are very slim and were easy to hide in the fairings. They emit a bit of a buzzing noise while on (louder when warming up, then they quiet down a bit). This is not a problem, there's no way I would hear them with the engine on. So.. starting clean: http://sheepable.com/media/f4i/hid/f4i_hid01.jpg This was the best place for the ballasts so they wouldn't be too visible. Since only half the ballast would cover the frame, using 2-sided sticky pads wasn't an option, so I decided to drill. 2 small holes and they were on super tight. http://sheepable.com/media/f4i/hid/f4i_hid02.jpg http://sheepable.com/media/f4i/hid/f4i_hid03.jpg http://sheepable.com/media/f4i/hid/f4i_hid04.jpg http://sheepable.com/media/f4i/hid/f4i_hid05.jpg The DDM kit was easy to install, but I had to trim a plastic spacer. Since this is an universal H7 kit, some bikes may not even require this spacer, while others could use it without modification. On my bike, some cutting was required. Also, had to pull the power wires all the way out and connect them to the stock headlight plug. http://sheepable.com/media/f4i/hid/f4i_hid06.jpg http://sheepable.com/media/f4i/hid/f4i_hid07.jpg http://sheepable.com/media/f4i/hid/f4i_hid08.jpg After that point, the install was pretty straightforward. I had to figure out which terminal was positive. The bulb doesn't care but the HID kit does. http://sheepable.com/media/f4i/hid/f4i_hid09.jpg http://sheepable.com/media/f4i/hid/f4i_hid10.jpg http://sheepable.com/media/f4i/hid/f4i_hid11.jpg http://sheepable.com/media/f4i/hid/f4i_hid12.jpg http://sheepable.com/media/f4i/hid/f4i_hid13.jpg Finished product (ballasts are barely visible): http://sheepable.com/media/f4i/hid/f4i_hid14.jpg http://sheepable.com/media/f4i/hid/f4i_hid15.jpg And some final shots. Considering that the bike was running PIAA's best bulb before (Xtreme White Plus), I like the end result. My camera's colors are slightly off -- the HIDs are whiter than in pictures (no blue tint) and the PIAA bulbs are a bit more yellow. 2 x PIAA: http://sheepable.com/media/f4i/hid/f4i_hid16.jpg HID low, PIAA high: http://sheepable.com/media/f4i/hid/f4i_hid17.jpg http://sheepable.com/media/f4i/hid/f4i_hid18.jpg 2 x HID: http://sheepable.com/media/f4i/hid/f4i_hid19.jpg http://sheepable.com/media/f4i/hid/f4i_hid20.jpg http://sheepable.com/media/f4i/hid/f4i_hid21.jpg HID bulbs fit perfectly: http://sheepable.com/media/f4i/hid/f4i_hid22.jpg Finally, a direct comparison -- HID low/PIAA high vs HID/HID low/high: http://sheepable.com/media/f4i/hid/f4i_hid23.jpg http://sheepable.com/media/f4i/hid/f4i_hid24.jpg |
