Will a few leds kill my battery if directly wired?
I ordered this, you guys may think it's cheezy or whatever but I think it will look pretty cool on my bike and I'm wondering if I can wire it directly to my battery and leave it running all the time with that back and forth motion. I know LEDs don't use much juice but this is pretty bright.
I did an LED kit on katrina. It was all buried under the plastics so it was more like a glow kit. I installed a switch so I could turn it on/off. You can wire to the battery, sure, but why? Why not wire to the bikes wiring? That way it is fused, switched etc...
And like the others have said, flashing/strobing lights will make you have a bad time with the LEOs.
I don't get it... it's a brake light... you don't want to use it as a brake light?
Anyways, I'd put a switch on it or wire it into the ignition. Your battery is not meant to constantly have a load on it when it's off... Even if you're riding your bike often enough to where it doesn't drain the battery, it'll weaken it over time and definitely shorten it's lifespan
I want to use it as a second brake light and to make me more noticeable to drivers. I was just thinking it would be kind of cool to have that on when it's parked outside of places. Kind of like the flashing light that comes with alarm systems. maybe not though! not a big deal, more curiosity than anything I guess lol.
10 x LED 5mm Red Slow Flashing Blinking Strobe Ultra Bright LEDs 1Hz Plane RC | eBay
Wire that to the battery (FUSED!) and put a switch on it (or better, an NC relay) so it isn't flashing when your bike is running.
Nothing wrong with a second brake light. These fit nicely on top of a license plate.
Put a switch on it so that when it's in your garage or wherever, it's not draining the battery. Leaving it on while you're at a restaurant..or bike night...or something will be fine. But if it's on 24/7 - it'll eventually weaken your battery. For the cost of the smallest and most simple switch - it's crazy not to put a switch on it when it'll eventually ruin your battery.
Sure, a second brake light would make you more noticeable, absolutely. Having one flashing at all times is just going to confuse people behind you and maybe cause an accident. If you want the faux alarm LED, get an LED like this:
