Why would this happen?
Old Dec 31, 2011 | 11:57 AM
Kevwa451's Avatar
Default Why would this happen?
I noticed on the highway unless I'm doing 80mph I get passed by everyone. This obviously leads me to believe that my speedo is wrong but everything on the bike is stock except for a Jardine slip on. I haven't checked with a GPS or the buddy method to see how bad the speedo is off but at 60mph I still seem to catch up to people in a 55 but on the highway 75 to 80 is the only way I can keep up with the flow of traffic.
Old Dec 31, 2011 | 12:23 PM
96shox's Avatar
check if gearing is stock or not.
Old Dec 31, 2011 | 03:28 PM
thebuch's Avatar
Do you have a smartphone or another gps? I'd just use that to figure out how fast you're really going, then you know if its speedo issues or if people are just driving that fast.
Old Dec 31, 2011 | 04:17 PM
jeffjones's Avatar
Almost certain you have a gearing change on your bike (-1 +2 or so) and no speedohealer.
Definitely GPS or something to verify it or count your sprocket teeth and find out what it was changed to.
Old Dec 31, 2011 | 04:38 PM
regener8ed's Avatar
stock tire sizes also? the speedo margin of error is known to sometimes be fairly significant on these bikes to begin with, any other modifications could easily compound that error.
Old Dec 31, 2011 | 05:19 PM
MadHattr059's Avatar
After I did the F3>F4i swap, I just had my wife hop on the highway, lock the cruise-control on 60mph and then paced her to verify that I still hit the mark.
Ern
Old Jan 1, 2012 | 08:08 AM
Kevwa451's Avatar
All gearing is stock, shoulda mentioned I changed the chain and sprockets this summer, the ones that came off were from the factory. I got one of the kits from RK but I kept the same sprocket sizes and chain width so that's all good. The tires are also the stock size. Unfortunately it's winter here in NY now so I'll have to wait until spring to see how much it's really off by. I just figured I'd ask and see if it could be anything I could fix over the winter while I've got my bike all tore down for a good cleaning, CCTL, and new fairings. Happy New Year.
Old Jan 1, 2012 | 02:24 PM
jeffjones's Avatar
Did you count the teeth before you installed the sprocket?
Maybe it was a mix-up when you ordered them? If not I have no idea.
Old Jan 1, 2012 | 06:45 PM
madman's Avatar
Uh, probably because 75-85 pretty much IS the flow of traffic.
Aside from the stock speedo being a bit off as they often are, the only other possibility would be tire size.
Old Jan 1, 2012 | 11:03 PM
Kevwa451's Avatar
Hhmm, well honestly the flow of traffic around here hovers around 70. You'll get the occasional 75-80 but you're guaranteed to get pulled over around where I live for going over 75. I thought maybe everyone was just flying but if I'm doing 71 on the highway in my car I pretty much pass everyone, but on the bike everyone passes me at 70 so idk. I'll figure it out this spring.
