Why does this happen?
Old 11-21-2010, 10:29 PM
MuscleswitCBR's Avatar
Default Why does this happen?
I've been riding for 3months in my 06 and every once in awhile when I really get on it and rev high in the rpm band my front wheel wobbles. Its not like bad or out of control but it does scare the **** outta me sometimes lol. The speed doesnt seem to matter I've had it happed right off the line and ive had it happen at as high as 120 when I kicked up. Why does this happen? What can I do to stop it? Thanks everyone
Old 11-21-2010, 10:37 PM
vangill's Avatar
July 2010 ROTM
its prolly coming off the ground a little bit, it is a sportbike-dampers correct this issue, as does a tighter grip or simply shifting your weight more to the front of the bike ie-scooting forward a lil more on the seat-that alone will change EVERYTHING when it comes to the wheel going off the ground
Old 11-21-2010, 10:40 PM
NateDieselF4i's Avatar
How hard are you jammin on it? At what RPM range? And what sort of bike?
Old 11-22-2010, 07:59 AM
__Z__'s Avatar
April 2011 Ride of the Month
here see answers.com def. speed wobble.... my guess that the higher rpm is causing your "frequency or vibration" and causing speed wobble... (even at lower speeds)
http://wiki.answers.com/Q/Why_do_you..._speed_wobbles
the only reason i disagree with vangil is because ive never had this happen to me at 135lbs. idk what you weight but i weight but its prolly safe to say your not pulling a wheel
however i do agree that a damper should fix your problem.... also you could check to see it your triples or forks are unaligned/tweaked at all, or get your tires rebalanced
Old 11-22-2010, 10:45 AM
vangill's Avatar
July 2010 ROTM
^im not saying your wrong z but im just saying that he might be scooted too far back on the seat, u prolly just have better seating position, i weigh 140 and it happend to me if i was bein lazy and sittin far back in the seat and bein to relaxed in my grip on the bike
Old 11-22-2010, 12:02 PM
Krux's Avatar
Agreeing with Vangil. It has happened to me. Matters were you put your weight at.
Old 11-22-2010, 12:55 PM
Jesus - I must be fat.
Old 11-22-2010, 01:10 PM
jp_greenville13's Avatar
Your gearing will also play a big factor
Old 11-22-2010, 02:38 PM
Krux's Avatar
How big are you? I am 140lbs same vangill
Old 11-22-2010, 02:41 PM
__Z__'s Avatar
Nates around 180 (he claims all muscle of course )I beleive.... haha idk why but him and I had a weight discussion
but like jp did say it also has to do with gearing i had stock gearing.... where as i know vangil had a different gear set up... im not sure about your krux
Quick Reply: Why does this happen?
