Who else needed a custom map?
Old Feb 23, 2006 | 08:16 PM
SquireSCA's Avatar
Default Who else needed a custom map?
I have a great PCIII usb map for an '05 F4i, Yosh TRS slipon, stock airbox.
Work was done by Charles at HFD1Motorsports, took him about 3 hours, on a Factory Pro Eddy-Current dyno. Takes awhile, but he does it in 500rpm increments, holds it there for 5 seconds to get a solid gas reading, and then tunes and tests and when it is dialed in perfect he moves to the next step. Much more thourough than a regular Dynojet run and guestimating based on the curve.
Here is a video of him testing it at 13,500 rpm, holding it there for 5 seconds and you can here it splutter a little bit, so he backs it down, makes an adjustement and then puts it back up to redline for 5 seconds and it runs like a champ. The bike picked up 3hp from when I walked in the door. Prior to Charles working on it I had another shop use a regular Dynojet inertia dyno.
http://www.metstaff.com/squiresca/F4...S%20Slipon.wmv
Anyway, anyone who wants the map, email me at nixond@gmail.com
Old Feb 23, 2006 | 09:47 PM
nxfedlt1's Avatar
Default RE: Who else needed a custom map?
hey, just wanted to thank you for your map, I appreciate it greatly.
Old Feb 23, 2006 | 10:13 PM
SquireSCA's Avatar
Let me know how it works for you. Most decent slipons should be fairly close as far as flow goes.
Old Feb 23, 2006 | 11:23 PM
kiggy74's Avatar
I've got the same setup except for an RS3 slip-on. Think your map would better than the Dynojet version?
Old Feb 23, 2006 | 11:26 PM
SquireSCA's Avatar
The dynojet map was crap IMHO. Can't hurt to try it.
Old Feb 24, 2006 | 01:23 PM
woogie's Avatar
What version of the TRS is that? Carbon?
Old Feb 24, 2006 | 02:49 PM
SquireSCA's Avatar
Yesh, carbon slipon, but that will not effect the flow. The pipe and baffle are the same, all that is different is the external can.
Old Feb 24, 2006 | 03:19 PM
woogie's Avatar
Gotcha. I figured that, but was curious with regard to the sound. Does the Titanium can sound any different?
Old Feb 25, 2006 | 06:51 AM
shraz's Avatar
wow funny to see a bike running that fast on a center stand
Old Feb 25, 2006 | 01:12 PM
kiggy74's Avatar
There's a Dyno shop in my town that does custom maps, I'm considering taking it because I can't really tell THAT much of a difference with the Dyno provided map. I'll tell you though, It makes me guts hurt to hear a bike hit rev limiter. If they did it to mine, I think I'd have to sit in another room. Kind of like watching your dog getting surgery or something....
