what tire pressure do you ride at?
its not about a plush or comfy ride.....the message is that having tire set at their maximum pressure is not ideal for grip and control...two factors I rate very highly, its quite a simple concept to grasp....tires set to Max pressure will have minimum contact patch with the asphalt and not warm up.... all contributing for less than ideal handling.
its like blowing up balloons to just before they pop...they have little give in them.
Sorry, sorry. I get a little worked up sometimes because I see all types of ridiculous **** when I check other peoples' air pressure.
I'm just saying that around 35/38 would probably be a good place to start and adjust for ambient/added weight (you don't have to do it all the time but if it's a big change then yes, you should). Lots of people run 36/42 (lots of owners manuals state this) which in general is going to give you the most life but from personal experience it's a bit overkill. I think it's recommended so your air pressure is correct for the most extreme scenario (really hot out/heavy bike/loaded up/2 heavy people).
As was stated before, it still depends on a lot of things especially your tire...as you can see Avon also carries a really stiff sport touring tire that requires more pressure. Most sport touring, sport and even hypersport tires require about the same PSI for the STREET.
So my not even close to professional opinion is 30-38 depending on temperature, load, and grip vs longevity (preference).
Or we could all stop making guesses with no type of formal education on the matter and just put the tires to the pressures listed on the dam bike from the factory. This isen't rocket science.
I retract my op to this thread. For some weird reason after reading this thread I noticed that 2 or 3 times today my rear tire slid a little while I was doing "quicker" downshifts before going into turns, and I felt like I could feel every single bump in the road.
Idk what pressure to, but I will be airing down my tires from what the manual says from now on for a bit better ride (and widen my center wear bar since I've just been dding the bike lately).
Thanks for the feedback Nickell, keep us posted on what you settle at and what the difference you have experienced....... there is no one correct answer but I think this thread has highlighted the importance of knowing your tire pressure & checking it often it has a huge impact on handling, mileage and tire longevity..
if your front end feels hard adjust your suspension, not your tires. you don't want underinflated tires. they're dangerous.
