600F4inoober |
10-22-2010 11:02 AM |
quote=boredandstroked;975598]I'll meet ya at pavs one night soon. You can come out with us on an airport run. Once you see what my f4i will do to most bikes in the group you won't be feeling so under gunned anymore. Or come down to wilcox the weekend of 23/24 for the track days. Last may at firebird I ran west track. On the back strait I would pass every single 600 and older 750's.
As for your temps, no thats how low it goes when it can. It won't be below 170 though.[/quote]
Preface-Boredandstroked, I'll be at the Pav's this Saturday, let me know.
I pulled this quote from another one of my threads regarding running "too cold"..anyway, last night it got down to the 50's here in the valley and given the temp will flucuate a little, I was cruising at 168!! Now it will jump up to 172-174 etc..but it seemed to stick at 168 while cruising...For some reason (and please talk me out of it) this seems too cold! I understand cold dense air is what you want for performance but in the same I understand that head/motor temp should be higher than 168 for effecient full combustion/non-knock/pinging. In the summer 90-110 degrees, it runs nice and warm (180-210) but now in the winter (ha..Im from chicago and Im calling the arizona 50/60 degree weather "winter" I should be slapped) it runs at 172 and now 168!!! I beleive my recent coolant change may have something to do with it...I purged as much 8000k old fluid as possible and filled with one bottle of Honda 50/50 (blue bottle) and the rest distilled water...Im pretty sure Im at at least 70% water possibly...Now I know the temps arent gonna go down to freezing, at least not enough to freeze the water I have in there on a long sit overnight (also that little amount of coolant will prevent freezing) but Im starting to feel that Im running too cold!
SO tell me if my assumption is wrong...upon starting the bike, the thermo (I assume stock is a 180?) stays closed while the engine attempts to heat itself...no flow of coolant...then at 180 the thermo opens fully and allows the flow to cool..the thermo stays open anywhere over 180 to maintain cooling...I assume when the temp gets below 180 that the thermo spring starts closing, only allowing a slight opening for coolant flow to heat up? So when Im running at 168 down the street, that thermo should be barley cracked if not damn near shut?! Dosent seem like it. <---Is this all correct? Just trying to learn:icon_playing:
