What Power Commander map do I use?
Should to a certain extent but the basic map in the ecu is a constant , a reflash of the ECU is best , which is what the Dyno run will do, but that is expensive, There are different types like Baazazz, have a look through all that is available to get the right thing for your bike, its worth the investigation first , dont rush into it, its your engines life we are talking about, Do you have an O2 sensor fitted
Have a look at this
https://bazzaz.net/fuel-control/z-fi-fuel-controller/
Couldnt find a Reflash ECU service for the 600f4i
With just a slip on you don't even need a power commander. A basic internet map will do nothing to help. Either get it tuned with a dyno to help with throttle response and what not or don't worry about it and leave it alone. But you can literally run 50,000+ miles with a slip on and no power commander as I did and be totally fine.
