what oil to use
Old May 10, 2006 | 04:14 PM
7gregory's Avatar
Default what oil to use
I was wondering if regular pennzoil 10w-40 oil is good and also I found wal-mart sells motorcycle oil filters they are frams. you think this will be good enough.
Old May 10, 2006 | 04:24 PM
woodyracing's Avatar
Default RE: what oil to use
i'm guessing by regular you mean car oil? if so the NO NO NO NO NO NO NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
the Pro Honda Oils (red cap) stuff is good, thats what I use in my streetbike. I use Repsol 4t 10w50 in my track bike.
and with filters, the stock one is considered one of the best available. If you want aftermarket the only one I can suggest is K&N.
I think the fram one has a reputation of breaking down and getting bits of cardboard in the oil
Old May 10, 2006 | 07:03 PM
F4iPilot's Avatar
DON'T USE AUTOMOTIVE OIL IN A BIKE!!!!!!!!!
automotive oil has friction modifiers in them to prevent friction. if you use them in a bike they will destroy a clutch since a clutch works off of friction and the same oil in the engine lubes the tranny also.....
go with Honda Pro oils. that is what i run in my '05 and use the stock filters....don't waste your money on a K&N filter...they are not any different from a stock filter.
Old May 10, 2006 | 07:48 PM
dwhite645's Avatar
Use Honda GN4 or HP4 (the HP4 is the synthetic if you want to go that way) 10w-40 and use the Honda oil filter. Other bike oil is ok too, but I stick with Honda pro stuff.
Old May 10, 2006 | 07:54 PM
Tahoe SC's Avatar
hey guys...it's ok to use dino oil in a bike...just have to change it more frequently.
do some research on it...there's lots on it.
Old May 10, 2006 | 08:13 PM
TBone's Avatar
I am into R4 superbike oil. I have however heard good things on the repsol. I would at bear min use a oil that is designed for a bike not a car. I guess enough has been said about the clutch and the tranny using the same oil as your engine. Not to mention that a car doesnt turn 10,000+ RPM.
Old May 11, 2006 | 01:52 AM
Jet Jockey Z06 Vette's Avatar
I'm just nearing my first oil change at 500-600 miles. Where is the best place to buy Honda oil online? Same with filters? Is there a bike shop that does good internet sales of oil & filters? That's what I'm looking for since the nearest dealer is over 30 minutes away each way.
Thanks!!
Old May 11, 2006 | 03:20 PM
Tahoe SC's Avatar
check it...do some research on it and not base this off of the fact that bikes spin way more RPMs than cars.
i posted here before, of blackstone lab results of a zx10r using dino oil. he changed it out at 4K, sent it to blackstone for testing. oil did show signs of break down. the recommendation was to change out every 2800 or so.
bike specific oils may just last longer than conventional car oils.
Old May 11, 2006 | 10:02 PM
scotty8583's Avatar
NO to motor oil, YES to Bel-Ray Synthetic EXS superbike oil!
Old May 12, 2006 | 02:50 PM
JAY 2002CBR's Avatar
I agree with Tahoe SC. You can use car oil in bikes, as long it is not labeled "Energy Conserving". You guys need to inform yourselfs. I suggest reading the article on Sports Rider website regarding oils.
http://sportrider.com/tech/146_0308_oil/
http://sportrider.com/tech/146_0310_oil/
