what oil and oil filter?
#21
I've never bothered using foil or pans or whatever. I just let it drip, try to get the filter out as quick as I can, and wipe the inside of the lower fairing with a rag when I'm done.
Oil changes take like 15mins. The limiting factor always seems to be how slow the new oil wants to go into the little hole...
#22
Same here... I don't take off the fairing or anything, just reach my hand in and unscrew.
#23
just did my oil change today, 2,700 miles on my bike, hadent done an oil change since the 600 mark like 2 yrs ago an realized even though i hadent reached 4k miles i was still overdue for an oil change.
this is the second time i use k&n (204) oil filter, surprised i hadent read anybody else use it, the old one was pretty hard to take off but am pretty sure thats due to the fact that it was almost 2 yrs since an oil change(bad i know, but was only like 2ks miles). and used 10w-40 castrol part synthetic motor oil for bikes.
#24
on
1 Post
Did my oil change today... first since I bought the bike.. I put 600 miles on it.. not sure the last time it was done, but oil looked good and filter was a honda.. put Rotella T 15W40 dino in it with a Mobil 1 M1-108 filter... shifting actually feels a bit smoother...
I used the alum foil trick for both the filter and the drain plug... worked great! thanks
#27
those big channel lock wrenches work good (the ones made for oil filters) if that doesnt work punch a screwdriver through it. usually if its REALLY REALLY bad you can crush the filter doen to where its almost flat and then u got a good surface to grab-but dont damage the threads it goes on to!
#28
on
1 Post
I was worried with my headers too, but I had zero problems.. I have about 6 different oil filter wrenches (strap wrenches) from all of the cars I have had or worked on....
I used one like this but it was made for smaller diameter filters:
I took the left hand side fairing off, went in from the side.. within 2 seconds it was loose and coming off...
Good luck..
Adam
Good luck..
Adam
#29
Adam,
That's the kind of wrench that I tried, but I guess I didn't try hard enough. I couldn't even get it positioned on the filter between the manifold. I'll give it another shot.
Vangill,
Thanks for the ideas. I think the previous owner thought things weren't tight enough if it was still humanly possible to remove it. I did my oil change a couple weeks ago and the drain plug felt just about as tight, except that I could actually get some leverage on it. The old oil looked clean enough, so I figured at that point I'd leave the filter on and deal with it later.
Vangill,
