what happens if...
i forget to put the kick stand up a few times and just put it in 1st gear. what damage will it cause?
( i mean the clutch is still pulled in) will it take out any clutch material?
There will be no damage to your clutch/transmission/engine etc. Like AMPFP said, the only thing that might happen is that your battery will drain from starting the bike without letting the alternator charge the battery. It will also put more wear and tear on the starter since you're using it more often.
For some reason, I get the feeling that the bike allows you to be in gear with the kickstand down, and if that's the case, your sensor is malfunctionning, but regardless of that, no real damage can be caused!
