Wax unit nut
No not changing. Had a throttle body issue so bought another one that seemed stock and came with everything but seems to me like the PO messed with the wax unit to prevent it from warming up on a cold start because when I installed the new TB the wax unit never worked and also cold started at 1000rpm until warm then went to 1300rpm. I noticed when I got the new TB the white paint was on the wax unit nut but also noticed the wax unit never moved either hot or cold. Just wanted to know what stock settings for the nut is.
Over time , with these Wax Units I've noticed they get a lot of blame for not working right,and a lot of the problem has been crud in the water pipes feeding the wax unit , might be worth taking a look at that first , you would have changed coolant if you changed the throttle body ,but did you clean the pipes, the increase in rpm points to that
That's how it looked when I got the new throttle bodies. Notice how the air flow ports are closed when cold? Are they suppose to be open and then closes when warm?
Just to add , depending on the ambient air temperature the wax unit can still be working ie on a warm day , so if its cold now where you live , would be the ideal time to set that top nut and then use some thread lock to maintain that position
OK so it's as I thought and the PO adjusted the nut so it wouldn't has idle. I got it idling now after the adjustment. Thanks. I notice though that the idle doesn't start at 2k but slow rises to it.
