Water pump..help
Old Jun 25, 2008 | 08:16 PM
faux's Avatar
Default Water pump..help
Im doing a coolant flush... and i remove well think i remove the waterpump drain screw i already drain the coolant thru the hose bt disconnecting it....and i pour water thru the rad cap but i dont see water comeing out of the pump..does someone know which screw or have pic... of which is drain.....
Old Jun 26, 2008 | 10:22 AM
MidnightG35X's Avatar
Default RE: Water pump..help
ORIGINAL: faux
The correct bolt on the water pump is all the way on the right as you are looking at it. There should be a small triangle on the metal pointing to the correct bolt. There is also a bolt on the cylinder block for coolant. That bolt is also on the clutch lever side of the bike, in between 2 headers. You can tell which bolt is correct because there is a copper washer on it. If you search around here, you can find the original factory service manual, which has all the info you could ever need.
Old Jun 26, 2008 | 03:50 PM
bluej511's Avatar
Next time try to search haha. Here is my DIY
https://cbrforum.com/m_510589/tm.htm
Old Jun 26, 2008 | 08:51 PM
faux's Avatar
Oman did i look but nothing like this came up i only got an RR flush...but thx
TW
Jun 2, 2015 12:12 PM
ucyifly
Mar 31, 2013 09:50 PM
anto1279
May 8, 2009 02:15 PM
Stunda
Aug 17, 2007 09:18 AM
Heaton830
Jun 2, 2007 01:17 PM
