Valve Adjustment Question
Old Apr 10, 2007 | 12:33 PM
yacobie's Avatar
Default Valve Adjustment Question
I took my 2002 F4i apart the other day to take the measurements for a valve adjustment and all of the exhaust valves were within service limits but the intake valves clearance has become more narrow somehow and I don't know exactly what this means. I do not understand how this could get more narrow. Do I just need to buy narrower shims or is something else wrong?
Thanks
Old Apr 10, 2007 | 02:35 PM
Tahoe SC's Avatar
Default RE: Valve Adjustment Question
yes valves can get looser (wear) and they can get tighter (seat recession). usually on the looser side though.
make sure you are measuring correctly and once you are positive, then swap out the shim for a smaller one so you get more clearance.
Old Apr 10, 2007 | 03:28 PM
Jaybird180's Avatar
I thought valve clearances usually tighten. But what do I know[sm=bangbang.gif]
Old Apr 10, 2007 | 08:50 PM
DTS_aka_cboe's Avatar
were your valves chattering cuz i thought i need a vavle addjus. but come to find they were all adjust. rite so i was bacfk to squre 1 then i was looking for the chatter and i found the my cam chain tensoner was bad put a new one on and no more chatter then ive talked to a few dudes and the same thing happined to there f4i so if you ever have a weird chater check your tensoner
Old Apr 11, 2007 | 02:28 AM
Tahoe SC's Avatar
it's actually 2 different types of sounds. once you hear both often you should be able to distinguish the difference.
Old Apr 12, 2007 | 05:48 AM
snobrdrdan's Avatar
Yeah the Cam Chain Tensioner Lifter (CCTL) usually only makes noise in the 5,000-6,000 RPM range and that's it
SO you'll definitely know when it's one OR the other
Old Apr 13, 2007 | 07:23 PM
yacobie's Avatar
Yeah man I replaced my CCT and that made a huge diff.
Blackdog91
Oct 22, 2012 07:32 AM
bundy26
Jun 21, 2010 10:16 PM
kellybarrs
May 29, 2010 05:52 PM
Jinx
Aug 25, 2009 11:36 AM
spooled/600f4i
Aug 6, 2008 07:30 PM
