undertail plate mount
Old Jun 5, 2010 | 03:00 AM
VTcbr's Avatar
Default undertail plate mount
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
Does anyone here have this undertail or any other undertail and would like to share how they mounted their plate...
thanks
Old Jun 5, 2010 | 07:16 AM
Combat_F4i's Avatar
Pimp bikes undertail. Got the bracket from Home Depot, had a piece of about 5''x.75 welded onto the end with two holes for my to attach my plate. Drilled 3 holes, two for the mounting brackets and one for the LED plate bolt wiring to go through the back. Did the wiring, attached the bracket (right infront of the pre drilled trunk lock barrel) Also drilled the holes for the signals I put on. I don't see it that hard to visulaize, but I can take better pictures if needed. Turned out great, but not perfect. When I made the bracket, there was enough resitstance for me to move it and it would stay in that position. With the plate and LED' bolts on it theres to much weight so it just kinda flaps around. The LED wiring going into the tail helps, as the heatshrink that goes through the hole is roughly the same size so it keeps it htat way. But I did it this way as the plate flips back and up and under the tail so I can use our toll highway the 407 that uses cameras for free.
Old Jun 5, 2010 | 07:26 AM
Indiana's Avatar
I dont have that exact one, but how my plate mounts is the same type of setup. I bought a universial tag bracket from ebay for $10. Works like a charm.....heres a active ebay auction link.
http://cgi.ebay.com/ebaymotors/Unive...Q5fAccessories
jch82
Jan 19, 2012 08:18 AM
VTcbr
May 29, 2010 07:31 PM
VTcbr
Dec 10, 2009 05:21 PM
Soyko
Oct 29, 2009 08:46 AM
JonJon
Apr 29, 2007 10:52 AM
