Undertail Paint Help Please!!
Old Nov 26, 2008 | 06:55 PM
LaughingMan600F4i's Avatar
Default Undertail Paint Help Please!!
Ok So I Got A Nice Undertail And I Havent Seen Any On Any Bikes So Far, But I Was Wondering I Have A Yellow 06 F4i And If I Should Take It To A Body Shop To Get Painted, Or Do It My Self...
So Far The Body Shops Estimated It At Around 300-500 Bucks...
100 Bucks At The Place I Used To Work Till I Quit But They Do Bad Jobs And They Screw Every One.
Or Should I Buy A Can Of Spray Paint From Home Dept. Or Something Thats A Really Close Color Shade And Do It My Self For Like 20 Bucks...
Hey Help Thanks.
Ima Located In Abbotsford, British Columbia, Canada..
If You Know Any One Around The Area That Can Do It.
Thanks, And Cheers.
Old Nov 26, 2008 | 07:05 PM
firemanron's Avatar
Default RE: Undertail Paint Help Please!!
since its a undertail, it wouldnt hurt to do the cheapo way. I have seen some undertails where people have when with a color shade lighter than the bike, but you couldnt really tell. So, I say go for it.
Old Nov 26, 2008 | 07:07 PM
Yeah I Was Thinking That Cuase I Have A Yellow Spray Thats 2-3 Shades Off But I Can Always Get Another One Or Order One In Just Wonder About Wear And Tare And If I Need To Sand The Undertail Or Not?...
Cheers,
Old Nov 26, 2008 | 07:24 PM
firemanron's Avatar
If undertail is in good shape, no need to sand. Just make sure you get it nice and even.
Old Nov 26, 2008 | 07:27 PM
Oh yeah Its Brand New So It Should be Know Problem Thanks
Cheers,
(Still Open To More Ideas)
Old Nov 26, 2008 | 07:31 PM
Rennen's Avatar
or you could paint it black like i did. i had an abs plastic grill for my car painted for $50. so $300 sounds like its waaayyy too much. but yeah, i vote black.
Old Nov 26, 2008 | 07:36 PM
Yeah But My Bike Is Gray And Yellow
Old Nov 26, 2008 | 07:38 PM
You Know What I Might Do That Black Under Tail Then Ill Spray My License Plate Braket Yellow That Will Look Sick I CAn Always Get Black Decals For 50-60 Bucks From My Friend Thanks
Cheers
Old Nov 26, 2008 | 08:59 PM
Stephens's Avatar
If you paint it yourself, I recommend you sand it down to rough it up with some 180-200 and prime it first then sand the primer with some 500 grit and then wipe it clean and the paint it.
Old Nov 26, 2008 | 09:18 PM
StrikeAnywhere's Avatar
If its ABS you need to sand it for sure and buy primer specifically for ABS which is available at most parts stores.
Sand part first
Prime and go ahead and put on 2 to 3 coats of primer since it will help the color stick
sand that with 600
lay on color and finish with clear if you want
I sprayed some forks black last weekend and used duplicolor clearcoat made to seal wheels. I put a ton of coats on and they came out great
