Turning Lock to Lock
I noticed that when I turn my bars left full lock that I get some interference with the hard parts (where the nuts connect) of the throttle cable. It seems to touch the fairing stay. I never noticed it before. Is the clearance that tight or did something become misaligned (fairing stay??) from my Trackday getoff? I've removed the front fairing to see it better and can't see anything wrong, except the interference. It barely touches the steering stop, but barely.
RE: Turning Lock to Lock
You can try bending it after you remove just the front fairing (leaving the stays). Just hold onto the upper as close to the lower stay as possible. If it's really out of whack you may be able to insert a pry bar through the triangular hole in the lower stay and use that for leverage.
If you have to do any bending on the upper stay it's probably best to heat it first.
Be careful. I have a crack in the middle of mine (dosen't hurt anything) and replacements are stupid expensive. They are usually the second thing busted in a crash so there aren't a lot of used "straight" upper stays running around.
Yeah, I told my buddy that his upper stay was jacked and now look at me. Why do Hondas always jack up the stay????? Maybe they should call it something other than a "stay". I'll give that a shot in a couple of days (maybe tonight?) I got the fairing off already, and all the plastics are in need of repair.
I just need to get her painted and lookin' pretty again, or make it a track *****.
Got the upper off. Still more head scratching
Here's photos. Not much help, but I'm stumped.
[IMG][/IMG]
[IMG]local://upfiles/7438/466B3508D9D941CDAB2AA5EB4049ECB9.jpg[/IMG]
[IMG]local://upfiles/7438/5046AA269284444099D7FDE32E187F6C.jpg[/IMG]
[IMG]local://upfiles/7438/6F28B8F74A8043DBBF461DE67F716FAE.jpg[/IMG]
[IMG]local://upfiles/7438/59ED5FAB51414F13801159EA401FF454.jpg[/IMG]
[IMG][/IMG]
