Tires
Old Jan 29, 2009 | 08:29 PM
wvcbrf4i's Avatar
Default Tires
My bike sets over the winter in a carport, and the tires are hard and have a shine to the top of them. when i ride the bike the backend tends to walk a lot around curves any ideas about a tire softner of any thing to get the grip back in them there only 9 months old
Old Jan 29, 2009 | 08:33 PM
xtreme954rr's Avatar
scuff them in (ride them hard but be carful )get rid of top layer of rubber, if that does not do it you will have to buy a set , good luck
Old Jan 29, 2009 | 08:34 PM
02f4irider's Avatar
or take some sand paper to um
Old Jan 29, 2009 | 08:47 PM
it would be alot more fun riding than sanding, sanding how long do you think that wiil take you,haha
Old Jan 29, 2009 | 09:09 PM
wvcbrf4i's Avatar
If i sand them will it really help im lookin to make them soft again has any one ever used tire softner to there tires
Old Jan 29, 2009 | 09:46 PM
02f4irider's Avatar
never used tire softener, i never put anything on my tires
as for sanding that will take that shine you have off then you can scuff them on the road
Old Jan 30, 2009 | 08:14 AM
F4iMane's Avatar
So just to make sure were on the same page, when you ride your bike its now hotter temperatures again for you where ever your at? And your premise is because the tires were cold over winter you think they got harder, and stayed harder even when the hotter weater rolled around?? Do you let your tires warm up before you ride also?
________
ROLL A JOINT
Old Jan 30, 2009 | 10:28 AM
02f4irider's Avatar
you tires generate heat as you start riding usual my tires are good to go in 20 minutes but that also makes a difference on what brand and compound
i have pirelli corsa 3s they're dual compound but they seem to wear alittle faster than expected. i use bt003s on the track there super sticky.
Old Jan 30, 2009 | 10:59 AM
alloutf4i's Avatar
Just do a few burnouts. That will work the fastest for ya
Getz2003
May 31, 2009 01:35 AM
Exitwounds
Oct 28, 2008 07:18 PM
Greyfox5
Jul 4, 2007 01:56 PM
barryem
May 14, 2007 02:12 AM
barryem
Apr 11, 2007 10:42 PM
