Tip Sensor for wheelies
Old Aug 11, 2006 | 09:03 PM
rancidf4i's Avatar
Default Tip Sensor for wheelies
Alright i was just curious how everyone was going about removing the fairings for, playing around with wheelies. I got the 1st gear down, and from 1st riding into 2nd. Fine but i want to practice doing just straight 2nd gear wheelies.
My problem is i want to remove all my fairings before doing them just in case, but the damn Tip sensor comes off when you remove the front fairing. I was wondering if everyone was rewiring their tip sensor or if there is plug that you can use for the wiring harness.
Thanks
Old Aug 11, 2006 | 09:15 PM
CBaRson's Avatar
Default RE: Tip Sensor for wheelies
You are going to have to search for it, but u can bypass the tip sensor by cutting the wires connected to it, im pretty sure you tie the 2 green wires together but i could be wrong...its been a while and i dont remember...
Old Aug 12, 2006 | 12:21 AM
ride_002000's Avatar
If you go down doing a 2nd gear wheelie your going to probably total the bike, even with the fairings off. Going that fast does some damage be careful and I say leave it on.
Old Aug 12, 2006 | 12:45 AM
woodyracing's Avatar
don't remove the fairings just get some cheaper ones, the fairings will protect actual parts of the bike like the frame, gas tank, subframe, engine case covers etc
to bypass the bank angle sensor just trace the wires from the sensor to the grey connector they go to and cross them off with safety wire or a paper clip, throw a good amount of tape to keep it in place and your good to go
sco7tys
Mar 27, 2008 06:41 PM
bmg velocity
Aug 24, 2007 04:17 PM
supeRstaR600
Apr 8, 2007 11:43 PM
9 fiddy fo
Aug 31, 2006 10:12 PM
