Tip over sensor
I just did the PAIR valve removal thing. It worked fine. I used some vacuum plugs on the outside of my airbox instead of valve caps inside, this way it can go back to stock really eazy if I need to. I want to say I feel a tiny increase in power from 3000 to 6000 rpm, or it could be wishful thinking. Anyway, saved a little weight?
-Josh
-Josh
does the air mod really produce more hp? afterwards, does the exhaust reek of un-burned gas?
I understand that colder air means more air molecules, but the trade off is that moisture is more condensed as well. That's why the intake air is warmed up: it allows for better ignition and cleaner burning.
