timing chain/cam chain replacement.
Old Jun 14, 2019 | 03:55 PM
  #21
shawn809's Avatar
Originally Posted by boredandstroked
Very unusual to hear the cam chain making noises on decel.
Not really. When you come off throttle there's not as much pull on the cam chain and without the tensioner doing it's job it starts to flop around. That's when I've experience the majority of my chain noise on both my street and dirt bikes. I had actually thought it was my drive chain at first, until i noticed the same noise while stationary.
Old Jun 14, 2019 | 04:00 PM
  #22
Bojan's Avatar
No doubt its a engine noise. Front and rear sprockets are new, including drive train. Tension is according to book.
Sound also auditable from RH side of engine, easy to hear it an isolate it from that side. Sòund is there almost all the time but its most present during deceleration and when maintaining speed.
It will be intresting ti test it with manual tensioner.
Old Jun 14, 2019 | 04:01 PM
  #23
Bojan's Avatar
I agree with you.
Old Jun 28, 2019 | 11:32 PM
  #24
shawn809's Avatar
Definitely sounds like tensioner. I know it's been a while, did you ever get it figured out? Just curious.
Old May 4, 2020 | 08:45 AM
  #25
Jacob Fiddler's Avatar
Default 40,000 miles can stretch a chain.
Originally Posted by stingray
i'd say don't worry about it. i've never known the cam chain to be an issue on these bikes. 40,000 miles is just broken in.
40,000 miles can stretch a chain to the point if replacing, especially if they are HARD miles. not so much the mileage but the hours and load of stress an experienced rider can put an extreme amount of stress on a chain when running wheelies and racing motor hard as it can. 😁. here's some pics to show you what to look for before you or anyone else decides to replace cam chain. and dont listen to anyone but your own educated opinion. because if it gets too lose can cause allot of damage,. and it'll be you not them spending the hours And hundreds to fix 😉🔧
left is new rights is old. notice how the old chain is longer. and the marks all over outside where it has benn slapping the chain guides.
Old Jun 13, 2020 | 11:22 PM
  #26
shawn809's Avatar
Call me crazy, but it seems I'm looking at two entirely different chain applications there. Personally, I wouldn't consider that picture a valid comparison.
Old Jun 14, 2020 | 06:55 AM
  #27
Doc Samson's Avatar
The little thread that could... just keeps plugging along, refusing to quit! I was going to comment about the chain pic but I'ma wait a few months...
Old Jun 14, 2020 | 07:00 PM
  #28
shawn809's Avatar
Post
I'll come back next year to comment on your reply
Old Jun 16, 2020 | 10:19 AM
  #29
chris0986's Avatar
I have clapping noises in my 954 too, but when I squeeze the clutch lever it turns silent.
Could it be the timing chain too?
When I checked the valve clearance I checked the timing too, and it was perfect.
I also saw a very tiny chain mounted to the clutch basket and it seems to be the oil pump chain.
This had quite a lot of play, could that be slapping around?
Altough I never have oil pressure problems....
Old Jun 18, 2020 | 03:00 PM
  #30
boredandstroked's Avatar
Same amount of pull but on the other side of the chain as the load is reversed.
As for the sound while decel, the problem with oem tensioners has never been a lack of tension. The tip's get loose to cause the rattle. All 3 oem's I've replaced still had great tension but the head that is pinned on and contacts the chain block gets loose.
