Timing a 02 F4i
Old Oct 16, 2021 | 06:52 PM
rover528's Avatar
Registered Users
Default Checking valve clearance.
Originally Posted by IDoDirt
Do you have the shop manual for your model/year? Not sure what you're referring to with 360 or 720. It's a 4 cycle engine, so crank is 2:1 ratio to cam shafts. That being said, you can't have the crankshaft 1 turn out. If the cam chain is not connected you put the cams in their proper location as described by the marks, then make sure the crank is in the right position. The key is to ensure that there is no slack in the cam chain on the right side, the side toward the front of the engine. After its installed and you've released the cam chain tensioner, manually rotate the crankshaft clockwise 2 full turns and ensure that the cams return to the proper position when the T mark is properly aligned.
When checking valve clearances, does the CCT need to be loose Or does is have to be in place with pressure against the chain. Wondering if it makes any difference.
Thanks
StrongPerf
Jan 2, 2010 04:37 PM
weekendrider
Feb 3, 2008 03:58 AM
allenpa5
Aug 16, 2007 02:59 AM
BiziB
Nov 4, 2006 11:54 PM
one2gofast
Jul 19, 2006 02:46 AM
