Tilt Switch Sensor
I have a 2001 Honda f4i and I wanna join the wires so if the bike falls it doesn't cuts out. Which wires do I have to join?
You unplug the sensor, and connect the two outside connections. Either with a wire or paperclip.
My question is why do you want to do this? There's the clean air box mod, but that takes a lot more work. I thought about but realized even if I wreck, I'd still be able to sell the engine, etc. |
zero alot of stunters do this mod....
or perhaps his sensor is broke and doesnt have the dough for a new one |
there is a search function that you can use to find your info.
https://cbrforum.com/forum/showthrea...ank+angle+pass try that link though zero what exactly is the "clean air box" mod do?? i had done some reading on it but was having trouble deciding if it would be worth while |
Its a stunt bike, so when i put it on the ground to spin around it keeps cutting out. There are green, red and red & white wires. A friend told me to join two of the wires but i can't remember which ones. Any idea?
you could also check on www.stuntlife.com
i think the green wire is the on you leave open...but i'm not really sure and don't have my bike anywhere handy to check. you should have a connector with three wires in a line (000) if you unplug it, put a jumper wire between the outer two wire points |
