Throttle too responsive?
Old Sep 2, 2010 | 10:33 AM
Kuroshio's Avatar
Default Throttle too responsive?
Ok i've had Ororo since April and i'm thinking its time to try adjusting the throttle. No matter what i try it seems the throttle has 3 positions: Off, On and On+
I can maintain speed in the lower gears with the tiniest rotation of my wrist. And the smallest speed adjustment i can make is about +3 mph. I know i'm better than that. Is there any way to adjust the throttle response without introducing slack in the cables? I want to fine tune the response, not change when the throttle kicks in
Old Sep 2, 2010 | 12:28 PM
Sick97SS's Avatar
Sounds like a gummy carb or sticky throttle plates. In neutral i can hold any rpm with precision. Jumpy "off and on" throttle is usually means the carbs can use a cleaning. on F3's (and other carbbed bikes) of course
Old Sep 2, 2010 | 12:38 PM
PlayfulGod's Avatar
sounds like you may also have a 1/3 1/4 turn throttle kit installed.
Old Sep 2, 2010 | 05:44 PM
jonld's Avatar
This is in the f4i section so what is it? If its a carbed f3 like your sig then check for the throttle kit previously mentioned. If its an f4i or fi bike, check the TPS out aswell as for a throttle kit. The honda bikes generally have a wide opening which is smoother especially the f4i. I put the f4i throttle tube on my r1 to make it less twitchy.
Old Sep 2, 2010 | 05:47 PM
Kuroshio's Avatar
Yeah one of these days I'll sit down with Photoshop and update my sig.
Ororo is my F4i. I doubt seriously the PO put on a throttle kit. He didn't strike me as the type. Is the TPS adjustable? I know when I broke down the carbs in my F3, the TPS didn't seem adjustable.
Old Sep 2, 2010 | 11:43 PM
jp_greenville13's Avatar
TPS on an F3?? That doesn't make sense. Correct me if I'm wrong but the carbed bikes have no use for a TPS...
Old Sep 3, 2010 | 05:07 AM
Kuroshio's Avatar
There is a throttle sensor on Carb #1 of my 95 F3.
Old Sep 3, 2010 | 07:30 AM
jeffjones's Avatar
"If its an f4i or fi bike, check the TPS out aswell as for a throttle kit."
Is what he said.Just to clarify.
Old Sep 3, 2010 | 07:43 AM
bambam's Avatar
throttle responce is night and day from carb to FI bikes, it was a interesting change for me from my 900RR to my 929RR, the throttle is extremely sensitive to any twist. takes a little getting used to , however i dont think you should try and make the thing LESS responsive. A little advice would be to find the right gear before your corner and hold your throttle position firm and ROLL into the throttle on exit. Kuro , you really need to update your siggy bro...peeps still think your on yer f3...
Old Sep 3, 2010 | 07:48 AM
Kuroshio's Avatar
Lol i know i know bambam. I've been working on throttle control in straight lines since i got the F4i. Like i said the best speed change i can get in lower gears is about +-3 mph. So i'm starting to wonder if i need to adjust the throttle.
I try not to corner heavily in 1st. Way too twitchy
