Swingarm spools
i have been looking at stands to help store my bike for the winter. I have noticed on some sites that they are saying most bikes come with places already in the swingarm to put the spools in. I was just wondering if the f4i swingarm had bolt holds to put swingarm spools or if i need to drill my swingarm.
Ok well some one in enlighten me, I am going to be doing the same thing when I pick up my wifes new F4 next week. I see the inserts and I hear you drill the swing arm, any pics? how do the stay in the swing arm? I assume you drill a hole and press them in from the out side? is it just a press fit? will this weaken the swing arm? Thanks
my bad guys
You have to drill a hole (the swingarm is hollow inside), put in these spool inserts and then basically thread a screw in and start tightening it down. It causes the insert to compress and then it cannot come back out. They are very stable and I have not had any issues.
One note. Whatever the thread size is for the insert, go to the hardware store and buy a nice long screw of that thread size. Do not use the ones that come with the kit. They are a little short for the compression part. I had a little trouble with one of them. Once you get the insert put in, you can use the screw that came with the kit to put the spool itself on.
