Stuck Trunk
So I finally got the bike from my buddy but with a stuck trunk. Pretty sure it's the lock that's broken, but for whatever reason I can't get it open. Are there any other ways to get in and pry the thing off? Can I get in from the bottom? I've only kind of looked at it, but it doesn't look like I can. I can semi pry the front of it up, but it's not going anywhere. Any ideas? It's a 2003.
Remove front seat and see if you can stick your arm up in the back area. You should be able to pull the cable to release the lock. I haven't tried it so if your arm doesn't fit, grab a coat hanger.
Your arm won't fit but you can disengage the latch by removing the front seat and pushing the latch open with a long screw driver
Yeah, my arm definitely won't fit in that gap. I got in there with a screwdriver, but couldn't get it to unlatch. I'll have to try again. Not sure if it's the lock that's stuck, or if it's the latch. Was hoping there was another way in from underneath, but from what I could tell, it's not possible without hacking away.
Originally Posted by jp_greenville13
(Post 1034241)
Might take a couple tries but its do-able |
the tail light is out of my f4 and i can pull the latch with my fingers :icon_angel:
Originally Posted by nickels
(Post 1034456)
I guess you can use an extended socket with a swivel head to reach the 2, 6mm nuts that hold the tailight in.....
Keep going at with with that screwdriver though. Courtesy of servicehonda.com http://images.powersportsnetwork.com...1-'03).gif |
Originally Posted by dveldtf4i
(Post 1034508)
Can you get the tail light out without pulling the seat? Have to check that out. I'm storing the bike in my mom's garage until I get it running so I'm only going to have weekends to get a look at it.
not sure buddy.... |
